856 Brake Leaking.
BFarr
12-07-2003 18:46:20
Well the snow is almost moved, but I have a leaking brake on left side that I assume to be o-rings.
I have the parts manual and I am currently trying to locate a repair manual..but would like to repair asap.
Is this a straight process.. remove the drum cover and remove a brake pack as a unit to replace o-rings??
Can anyone help.
Thanks
Gary-Miss
12-07-2003 18:56:19
 Re: 856 Brake Leaking. in reply to BFarr, 12-07-2003 18:46:20
As I recall, you remove this entire pinion at one time, in one piece and take it to the bench to do this work. Check a little morefirst, though. You don't want to drop something into the transmission like the differential.
BFarr
12-08-2003 16:17:53
 Re: Re: 856 Brake Leaking. in reply to Gary-Miss, 12-07-2003 18:56:19
Thanks for the response. I got it apart tonight, a simple unbolt, step at a time. One o-ring shot, seal worn and a ratchet missing. Dealer is sending over parts.
