Farmall H thermostat, opening temperature? NAPA
aaron
12-08-2003 10:45:31
Hello,
I am putting my H back together and would like to install a new thermostat while it is apart. What opening temperature is appropriate for the Farmall H? I assume that I can get one at NAPA? Anybody know what NAPA part# to ask for? Thanks,
Aaron
Brad L
12-09-2003 18:58:09
 Re: Farmall H thermostat, opening temperature? NAP in reply to aaron, 12-08-2003 10:45:31
I put in an IH thermostat and it worked good twice and now acts like its sticking open.
Bob M
12-08-2003 10:55:37
Stock H thermostat is 160 degree. However I've found my Farmalls run better - especially in cold weather and under light load - with 180 or 192 degree thermostats installed. I've gotten replacement thermostats at AutoZone. They look different from the original but fit and work fine. And the price is right at $3.99! If memory serves the Autozone stock number is 800-180 for the 180 degree unit - NAPA should be able to cross that number for you.
Brian Schmidt
12-09-2003 17:10:46
 Re: Re: Farmall H thermostat, opening temperature? in reply to Bob M, 12-08-2003 10:55:37
Thanks for the data Bob M. I bought a thermostat at IH last week for $17.99 and was about to put in in until I read your post. I went to AutoZone today and bought the 800-180 for the H. $2.99. Worked real good. You saved me a few bucks!!!
Thanks!!!
