Wide Front For A Mid 40's H Farmall
Warren Mehlberg
12-08-2003 19:53:15
What is the availability of a wide front for my H Farmall? IH preferred but aftermarket=OK. How much do they usually go for? Anyone have one for sale? Thanks, Warren
rustyfarmall
12-09-2003 04:34:04
 Re: Wide Front For A Mid 40's H Farmall in reply to Warren Mehlberg, 12-08-2003 19:53:15
A very nice, original IH wide front sold on e-bay recently for over $700.
42FarmallH
12-08-2003 20:30:27
I sold a perfect original IH wide front a couple years ago for $400 - that was cheap. Consider yourself lucky if you can find a good original IH for that price (tie rods out front).
Used Schwartz are easy to find and cheaper to buy, and they are built stronger. I put Schwartz heavy duty wide front on my H, plan on having a loader for it someday.
I've seen several original IH wide fronts for sale, ranging from $250 for a poor one, all the way up to $900 for a perfect one with good paint, wheels, and tires.
If you really want original, I might be able to get one from an M (if it is still there) for about $600, would trade for narrow front and $500. Good luck!
Allan
12-09-2003 04:32:37
 Re: Re: Wide Front For A Mid 40's H Farmall in reply to 42FarmallH, 12-08-2003 20:30:27
Hi Warren,
People have been telling me that the M and H front ends don't interchange...
Do they?
Thanks,
Allan
42FarmallH
12-09-2003 06:19:14
 Re: Re: Re: Wide Front For A Mid 40's H Farmall in reply to Allan, 12-09-2003 04:32:37
They will interchange from the H through the 450 for sure, since my wide front came from a 450 that I put on my H.
The differences: the plate that sets the old style tie rod in front of axle front end back further is wider on the M - you will need the H plate to set it back (if you want it set back). And the steering arm has the holes spaced wider on M thru 450 vs the H thru 350 - I slotted the holes with a torch to make the 450 arm fit my H.
sod
12-09-2003 06:49:47
 Re: Re: Re: Re: Wide Front For A Mid 40's H Farmal in reply to 42FarmallH, 12-09-2003 06:19:14
Steven?
good luck
sod
42FarmallH
12-09-2003 10:06:09
 Re: Re: Re: Re: Re: Wide Front For A Mid 40's H Fa in reply to sod, 12-09-2003 06:49:47
Yep, now you and KellyC have figured it out :o)
Steven@nd
sod
12-10-2003 00:55:47
 Re: Re: Re: Re: Re: Re: Wide Front For A Mid 40's in reply to 42FarmallH, 12-09-2003 10:06:09
I hope things are going well for you and yours.
Hey Kelly C...How about a day of haying and making my 450 do the work for which it was designed? It will be in Hinckley next summer and the little bro would be up for a haul down there just to see it work.
good luck
sod
Kelly C
12-10-2003 04:50:53
 Re: Re: Re: Re: Re: Re: Re: Wide Front For A Mid 4 in reply to sod, 12-10-2003 00:55:47
Sure cant turn that down :-).
Give me a email when your up or coming up and see if I have any going that weekend. I will let you run the baler all you want :-)
Kelly C
12-09-2003 11:31:56
Hey Steve.
I see you are selling the H again. Wish I had a couple grand around to give you for it.
Got a suggestion for you though. The only thing thats keeping that mean machine from bringing what you want is the paint.
Sorry to say it but most people are drawn to the sizzle rather than the steak.
You could have a total POS and if it looked good you would get more out of it.
Go get a gallon of IH2150 wash her down and paint it. Dont even have to knock out the dings.
Be sold in a week. Betcha.
42FarmallH
12-09-2003 11:34:04
 Re: Re: Re: Re: Re: Re: Re: Wide Front For A Mid 4 in reply to Kelly C, 12-09-2003 11:31:56
I know, paint sells. Thing is, price is set so high no one would even buy it with fresh paint. Basically, I can't say no to the amount of $$ I'm asking - don't know if I would ever sell it. I have power steering kit on the way for it - going to have the live hydraulics on by this summer too!
Take care!
Kelly C
12-09-2003 11:44:51
 Re: Re: Re: Re: Re: Re: Re: Re: Wide Front For A M in reply to 42FarmallH, 12-09-2003 11:34:04
Make sure you document the hydralics real good. I plan on buying a cheap M with my hay money this next fall. Going to put my big loader on it.
Live hydralics with a bale spike in the back and one on the loader. I would have a bale moving machine!!!
