f20 tractors identify and value
d shaffer
12-08-2003 20:22:51
we are looking someone who can help us identify what we think are f20 tractors 1 has a mounted cornpicker . our local foundation owns them and we would also like to know what value they may have.
Bill Smith
12-09-2003 11:24:21
 Re: f20 tractors identify and value in reply to d shaffer , 12-08-2003 20:22:51
As mentioned by Dick, you should be able to find some photos of F-20's in the photo archives. Be careful, because the F-20 looked real simular to its former model the regular. The regular had open steering gears and the f-20's were enclosed. The F-20 also looked simular to its larger and smaller versions the F-30 and the f-12 or 14. If you seen them in person you would notice the difference in size right off, but maybe not in a photo. You should be able to note differences by looking at some photos of identified tractors. The f-12 and f-14 I beleive had a fuel pump and the f-20 didn't. The f-30 had a gas tank that looked sort of like a square box in shape, but the f-20's gas tank is longer from front to back than it is up and down. Look at some photos and check it out. An F-20 can range in value from $100 to around $1200 depending on what kind of shape it is in. In other words one that don't run, tires shot, rusted up bad with parts damaged beyond use or missing is worth only about a $100 to a scrap iron guy or somebody that will part it the rest of the way out. One that is restored should go for over $1000.
Nebraska Cowman
12-09-2003 04:14:42
I would be very interested in an F20 with mounted picker. Our tractor club hosts an annual picking day and has connections with the County farm museum too. Also I am a collector of F20s myself. Please email me.
Dick Davis
12-08-2003 22:10:58
You need to provide a little information to receive a meaningful answer to your posting. Do you want someone to come look at the tractors to identify? If so where do you or "local foundation" live? If you want people to guess what you might have, a picture would be a big help. If you describe the tractors in some detail, our panel of experts can help you. As far as potential value condition and location are again big factors. If you go to Tractor Photos under Galleries in the left margin of this page you can find several F-20's and should be able to confirm your machines identity. Don't mean to sound like a smart aleck but if you reread your post you can see the shortfalls. My nickel.
