M.D Throttle problem
Newt
12-09-2003 14:19:32
On my M.D It seems Iam not getting full throttle.As I have just purchased this tractor Iam not sure how much acelleration the the engine speed control lever should have. It seems the only throttle advance is from the middle position to full throttle and that is not very much. In full throttle it does not seem to really rev up. also the engine speed control handle seems really loose until you push it way up to full. Would air in the system maybe cause this situation. I know the filters were changed prior to me purchasing it. I dont know if he bleed the system. Any help would be greatly appreciated.
49 Cubber!
12-09-2003 18:23:06
 Re: M.D Throttle problem in reply to Newt, 12-09-2003 14:19:32
On my SMD,there apparently was some sort of problem at one time,the linkage from the end of the throttle shaft has been reworked and an old tie rod from what looks like the same one on my truck replaced it,accoprding to what I was told its suppose to be like the steering on a lawnmower with the ball and socket.
Haas
12-09-2003 14:22:52
The linkage on that throttle is kind of complicated, going through a device mounted on the side of the engine block. I suggest you get a service manual which will tell you how to adjust the linkage.
Farmaller
12-09-2003 17:27:15
 Re: Re: M.D Throttle problem in reply to Haas, 12-09-2003 14:22:52
Unhook the linkage at the pump with tractor running and pull back on pump lever. If you get more out of it,you need to adjust linkage to the pump. If not then you can adjust it inside the pump, but if this tractor has an old tired engine I wouldn,t run it that hard anyway.
Newt
12-09-2003 14:42:04
I have the manual for the tractor. Iam just wondering if what Iam describing is normal for the M.D.
Haas
12-10-2003 06:30:48
 Re: Re: Re: M.D Throttle problem in reply to Newt, 12-09-2003 14:42:04
Your description does not sound normal. You will need a way to meaure RPMs to know for sure.
