Please Help identify a 214 IH plow
Randy G
12-09-2003 21:26:52
I have a 2 bottom 14" IH plow but do not know the model or year produced. The beam numbers facing it from the back are: beam on the left #P012572, on the right #P017184. It also needs a coulter blade with holder if some one can direct me as to where I can locate one. It also has 2 spare shares if anyone needs one. Please help me with as much as you can. Thank you.
GP
12-10-2003 08:52:58
 Re: Please Help identify a 214 IH plow in reply to Randy G, 12-09-2003 21:26:52
Sounds like an IH/Mcormick Little Genius, likely a No. 8 if the tail wheel turns. If the tail wheel is stationary it would be a Little Wonder. Your best bet for parts would be a salvage yard, or place a wanted add in the classifieds on this site.
Randy G_______more info
12-10-2003 08:29:40
The plow is a pull type, is has a hook shaped tounge pointing toward the ground, has 2 steel wheels, one larger than the other, it has 2 levers that manually raise or lower it, has a tail wheel thats pressed steel with several holes in it. Hope this helps. If more is needed let me know.
earlschieb
12-10-2003 05:39:30
Well I agree with Hugh about more details needed, if nothing else post a picture of it on here. As far as coulters goes, I have a nice pair of Lantz coulters that I would sell that should fit that plow, they are complete, unbroken. You can email at the above addy. But post a picture if you can, it would help alot.
Hugh MacKay
12-10-2003 03:35:00
Randy: To start with is this plow 3 point, 2 point fast hitch or trailer. Does it have a tail wheel or a long landside. I have parts books here that cover a lot of IH plows. Answers to the above will narrow it down a bit. Right now It's kind of like looking for needle in haystack.
