B Rebuild
gauger
12-10-2003 05:48:36
I'm doing an overhaul on a "B", judging by the casting numbers, the block is from a Super C and the head is from an early C113. The engine has 3" pistons. The 3 1/4" sleeve and piston set will work in the block. Any problem using the C113 (6716 DB) head with the bigger pistons?
parts man
12-10-2003 19:12:46
 Re: B Rebuild in reply to gauger, 12-10-2003 05:48:36
You shouldn't have any trouble with going to the bigger pistons, most people do that with a rebuild now, and some after market companies only sell the 3-1/8 piston and sleeve sets.
