Adding hyd. remotes - 1066
Mitchissippi
12-10-2003 08:24:23
I am running a 1066 with 2 pairs of hyd remotes on the back.
I have another 1066 parts tractor with the same setup.
Can I add the 2 pairs of remotes and levers off the parts tractor to the 1066 I'm running?
I don't have a need for more hyd. hook-ups now, but if I had them available, there's no telling what I could dream up.
Thanks,
Mitch
bermuda ken
12-10-2003 11:24:35
 Re: Adding hyd. remotes - 1066 in reply to Mitchissippi, 12-10-2003 08:24:23
If one of the remotes has a bolted side plate you COULD have upto 4 remotes. If the plate is missing, 3 would be the limit.
You will need to build new control levers and remove the LH seat support to install the valves. It will be a VERY tight fit for installing and line plumbing.
You will likely find the remotes #3 and #4 do not seem to have the oil flow that #1 and #2 do.
Mitchissppi
12-10-2003 14:34:15
 Re: Re: Adding hyd. remotes - 1066 in reply to bermuda ken, 12-10-2003 11:24:35
Thanks Ken.
I am going to keep that idea in mind. I'd like to be able to run 2 dirt buckets in the future.
Mitch
bermuda ken
12-11-2003 05:56:22
 Re: Re: Re: Adding hyd. remotes - 1066 in reply to Mitchissppi, 12-10-2003 14:34:15
You could get one of those hyd valve multipliers and get the extra outlets added to the tractor for less cost too!!
Mitchissippi
12-11-2003 07:17:24
 Re: Re: Re: Re: Adding hyd. remotes - 1066 in reply to bermuda ken, 12-11-2003 05:56:22
I will look into that route if I get serious about this project.
Thanks,
Mitch
