What is TA
week N warrior
12-11-2003 05:47:46
I've been trying to figure out what TA stands for and what it does. The archives didn't help any. I keep hearing it referred to and I take it that it has something to do with the transmission but that's all I know.
Carl
jason
12-11-2003 15:30:52
 Re: What is TA in reply to week N warrior / MO, 12-11-2003 05:47:46
ta is for tourqe amplifier. it was ment so you could plow at a faster speed in light soil and then when you go into harder soil you could pull it back an not have to down shift. it gave a 45% rise in torque when it was engaged. No, I don't think there would be any aftermarket parts to convert an H/M you had to get am M-TA but it came standard on later models.
Jim Cox
12-11-2003 10:56:56
Hey carl, I think it's 'torque amplifier'
Jim Cox
Richard Fazio
12-11-2003 10:56:43
This has probably been asked before but I can't seem to find it. Can you add a TA on tractors without one, for example, I'd like to put one on my 48 M.
Hugh MacKay
12-11-2003 06:44:06
Technically it just operates like a 2 speed power shift. All makes of tractors had a version of this by 1990. Today most of them are multi speed.
Kelly C
12-11-2003 06:17:39
In short its the part that is broke on every Number series Farmall that you can buy for a good price. :-)
Acctually:
The Torque Amplifier unit. Provides gear reduction through the use of a planetary gear set.
It is between the main engine clutch and the transmision. It has its own clutch disk/ Throwout bearing ect.
With the clutch ingaged it is in direct drive. With the clutch disingaged it is running the planet gears and sun gears giving apx gear reduction of 1.48 to 1
todd hamilton
12-11-2003 18:09:44
 Re: Re: What is TA in reply to Kelly C, 12-11-2003 06:17:39
Greetings from the Case board. I have been around many IH numbered models in my extended family and I must say that this the most accurate post I have read in quite awhile!:^)
week N warrior / MO
12-11-2003 07:57:45
Thanks everybody for the replies.
Why is it always broke?
Is it fragile?
Or does the tractor still work without it so no need to fix?
Is it expensive to fix or hard to fix or just hard to get to to fix?
Carl
Kelly C
12-11-2003 09:24:50
 Re: Re: Re: What is TA in reply to week N warrior / MO, 12-11-2003 07:57:45
From some I have read they are broke from miss use.
According to Hugh and others, used properly you should never break one. It seems many have though.
I think you hear alot about it here because we are a buch of cheap skates. Always looking for that diamond in the rough.
Right now I cant tell you how hard it is or how much. I havent done one yet. Wait a few weeks I can let you know when I am done with mine.
paul
12-11-2003 17:39:36
 Re: Re: Re: Re: What is TA in reply to Kelly C, 12-11-2003 09:24:50
pulling heavy hay wagons down hill with the tractor in high an then trying to slow down with the so called brakes on a super m ta is no fun. most operators panic and throw the ta in low and then KABOOM broken sun gear teeth. my little brother did this and i thought dad was going to beat him within an inch of his life. paul
Hugh MacKay
12-11-2003 16:59:08
Kelly: I'd like to qualify that statment. Back 45 years ago when these tractors were relatively new, many people had trouble with TA, much of it caused by letting tractor free wheel in low, improper adjustment, improper oils, etc. Keep in mind these tractors were probably the first tractors in history where close in adjustments was no longer good enough, and secondly it spelt the end of the saying,"If all else fails consult the manual."
The result of all this is many TA's packed up in the 1000 to 3000 hour range, long before they should have. Factor into this TA was also a pioneer attachment. Who was at fault is a hard call. I personally feel IH should have put a few more development dollars into TA and perfected it much sooner. Example freewheeling should have been history within 5 years.
We have absolute proof IH was on the right track with TA. Every major tractor manufacturer since has gone to 2, 3 and 4 speed power shifts. Deere and Ford both had complete power shifts for a number of years. That seems to have disappeared in favour of the gear drive transmission with 2 to 4 power shifts.
Having said all of this, I will declare that it was possible to take a new 300, 400, etc. and put 10,000 hours on TA without trouble, if proper care and maintainence was adhered to.
Another factor you are facing today is, as commercial farmers upgraded their tractor fleets, older Farmalls such as MTA, 300, 400, 350, 450, etc. became the tractor you parked at end of field with wagon and seed and fertilizer, or that spare tractor. The fact that when TA packed up the tractor would run for years in direct drive with no repairs, they were just left in that state of repair. No question in my mind Kelly, you could well be doing TA on a 400 that has been as it is for the past 25 years. To these farmers a 400 with low side out on TA was just as handy as a Super M
John In Iowa
12-11-2003 20:09:58
 Re: Re: Re: Re: Re: What is TA in reply to Hugh MacKay, 12-11-2003 16:59:08
Hugh,
One of the hardest things on the TA was shutting down the tractor with the TA in the high side. If you ever had one apart you would see that if the engine turns backwards, such as dieseling when shutting down, with the TA in the high side everything locks up, sending a terrible shock through the TA with the overriding Clutch taking it the worst, causing flat spots on the ramps and rolling which lead to the clutch not locking up the go in the low side. If you shut in down with the TA in the low side everything with turn free to the transmission.
John In Iowa
Hugh MacKay
12-12-2003 02:17:16
 Re: Re: Re: Re: Re: Re: What is TA in reply to John In Iowa, 12-11-2003 20:09:58
John: Read what I said about letting tractors diesel in thread above re: the 450. You are quite right about stopping TA equiped tractors by placing them in one of higher gears and letting clutch out as you hit the ign switch. Bad enough if it kicks back in neutral.
John In Iowa
12-12-2003 08:25:29
 Re: Re: Re: Re: Re: Re: Re: What is TA in reply to Hugh MacKay, 12-12-2003 02:17:16
Good advice about kicking the driver when shutting down a hot tractor. A friend of mine that owns a CaseHI dealership told me that his dad said that because the early diesels had so much iron in the head and that farmers never would give them time to cool out before shutting down that they would crack the head. His dad told him when he went from working in the shop to sales that if he traded for one of those early diesels (MD, 400, 450) that he was fired!!!
Hugh MacKay
12-12-2003 14:25:23
 Re: Re: Re: Re: Re: Re: Re: Re: What is TA in reply to John In Iowa, 12-12-2003 08:25:29
John: On the weight of those engines, I remember once removing engine from Farmall 300 to send it for a rebuild. We happened to have Chevy 283 cu in in shop at the time. We put them both on scales, I forget the figures but the 300 engine was heavier.
Kelly C
12-12-2003 03:47:52
Very interesting.
My 400 diesled like crazzy when I 1st got it.
In its life before me I think it was primarily a loader tractor. Not a whole lot of hrs at any one time to heat the engine up good.
After doing 20 acres of hay. Raking it and baling it. My 400 quit diesling.
John In Iowa
12-11-2003 20:28:45
Hugh,
Here is a post I made with I had to rebuild my TA on my 400 in 2001
Posted by John In Iowa on February 06, 2001 at 22:58:46 from (199.108.164.20):
After seeing a lot of posts about what causes a TA to go bad, I thought I would take the time to set things straight as I sit here tonight with my 400 sitting in a neighbor’s garage split in half and the TA case sitting on the bench with parts covered with clean rags waiting for Uncle Sam to return some of the money that he has borrowed from me (tax return). I got this 400 Farmall back in 1991 with the engine stuck. After rebuilding the engine and hearing it run, I was filled with joy only to discover that the over running clutch in the TA was weak. I did find out that after letting it warm up good that the TA would work most of the time. That was until this winter. I pull up to shed and got off to open the door to put it up for the night when the engine backfired, shuttled and came to a stop. The last time I heard an engine do that was when our family’s M broke the cam gear on the cam shaft (that’s another story). I pop off the disturber cap and found that I could turn the rotor any which way very easy and that my worst fears was coming to past. I got the other tractor out and push in the shed for the night and looked at it in the mourning. What I found was that the coupler from the hydraulic pump had come loose and the half moon key fell out. After putting everything back in order, I fired the old girl up and thought I would take it around the yard just to make sure everything was in order. I couldn’t move!!!! What I had found was about half the clutch face from the TA clutch laying in the bottom of the case and yes I had the TA in the high side. After taking it apart, looking at the TA and talking with some old IH hands I now understand what happen. The way the TA works is like this. You have an input shaft coming in from the engine that goes in to the planetary gear set. On this same shaft you have the TA clutch on it. On the gear set you have the pressure plate on the front side and the overrunning clutch assembly on the backside with the output shaft running through the overrunning clutch but not connected to it going to the output of the gear set. The outside part of the overrunning clutch assembly is bolted on the back bearing cage of the TA case. In this assembly you have 8 rollers that run up a ramp that lock the outside of the planetary gear cage to the back of the case, thus letting the input shaft turn the reduction gears in the gear set. On the high side with the clutch engaged the planetary assembly is lock with the input shaft, thus the output shaft is lock with the input shaft and turns the same as the input shaft. In the low side the clutch is released allowing the planetary cage to turn the opposed way until the overrunning clutch locks it to the back of the TA case stopping it and letting the reduction gears go to work. You would think that this would send a lot of shock through the TA but with everything moving it doesn’t. Were the real damage comes in is when the engine kicks backwards when you shut it off in the high side. With the planetary set locked to the input shaft with the TA clutch engaged, not letting any energy to go through the gear set and out the output shaft, it turn the opposed direction which engages the overrunning clutch which in turns brings everything to a halt. This is when you get a terrible shock through the whole TA assembly. One of the things that suffers the most is the rollers and the ramps in the overrunning clutch causing flat spots on the rollers and the ramps. With flat spots in the rollers and ramp its hard for the rollers to run up the ramps to engaged the overrunning clutch. In this case with me the overrunning clutch did hold this time tearing out the clutch in the TA. Coasting with the TA in the low side only lets the overriding clutch work like is suppose to, the same as if its in the high side. Hope this clears up some of the Myths out there.
John In Iowa
Joe Evans
12-11-2003 07:23:29
Quite right. A common and insidious disease it is!
ken
12-11-2003 06:03:47
torque amplifier as for whats involved in it i have my theories and ideas from looking at other posts so i'll leave that up to the experts that have had them apart and so on
ken
12-11-2003 17:30:30
 Re: Re: What is TA in reply to ken, 12-11-2003 06:03:47
well jon can't ya tell i'm running for office,telling ya what ya think you want to hear and making you feel good about it.
Jon Blanc
12-12-2003 05:06:13
 Re: Re: Re: What is TA in reply to ken, 12-11-2003 17:30:30
In that case you got my vote!
Jon Blanc
12-11-2003 07:26:58
So, Ken did you major in journalism or communications? LOL
