Farmall 460 sleeve removal
Paul K.
12-11-2003 07:04:54
Could someone please tell me an easy way to remove the sleeves from the block. Is there a secret to doing this and can I do it with the block left in the frame. These are dry sleeves I believe. Thanks, Paul
Jim J
12-11-2003 13:49:03
 Re: Farmall 460 sleeve removal in reply to Paul K., 12-11-2003 07:04:54
I build all of the sleeve pulling disc's that I use and I could build one for you.
Lloyd
12-11-2003 13:34:56
The safest way is with a sleeve puller. Search the archives and you should get some ideas about how to get one made for you. You shouldn't need to remove the engine to get the sleeves out.
E J
12-11-2003 09:27:37
Weld a small bead down each one they shrink pull them out.And keep the slag from getting on the crank.
