wd 6
Mark
12-11-2003 09:58:42
What is the best replacement plug for these tractors? D-16 champion? I was told the long reach elctrode type was not available.
Bill V
12-12-2003 08:27:24
 Re: wd 6 in reply to Mark, 12-11-2003 09:58:42
I don't remember the number but you can getthe reach plugs. Thay will be AC but thay are available.
brianh
12-12-2003 05:22:32
I put D-89Ds in my MD because that's what the book calls for, and it runs great. HOWEVER, I just got my PD-40 running, and it has W-18 standard plugs in it for gas start -- that's what it's manual calls for, and it starts just as easy as my MD. It would be interesting to put D-18s or some other standard plug in an otherwise good running MD or WD-6 and see if it makes any difference in the starting.
justin
12-12-2003 08:01:08
 Re: Re: wd 6 in reply to brianh, 12-12-2003 05:22:32
I thought the Champion 44 (not sure what it crosses to) is the correct plug for the 40 Diesels, 80 diesels, TD14 & TD18..
brianh
12-12-2003 10:06:22
 Re: Re: Re: wd 6 in reply to justin, 12-12-2003 08:01:08
I had heard that too.... my PD-40 is a very early one (vertical injector head) so maybe that's why it calls for the W-18s?????
justin
12-12-2003 07:56:07
justin
12-11-2003 18:32:41
I have some NOS Champion 44 spark plugs (original plug) for the gas start diesels at $5/ea
Fredwi
12-11-2003 15:23:59
Hi, mind did alot of backfiring until I took off the cap and cleaned it all up and put on new plug wirers with new plugs, I have to fiddle with the choke rod alittle but you can tell when it starts to rev up. Good luck. I bought the D89D plugs and got them at the local Case/IH dealer. Fredwi
Fredwi
12-11-2003 15:18:57
Haas
12-11-2003 14:38:23
The correct plug for the WD6 (same as the MD) is a Champion D89D. I got mine from an IH dealer. However, I asked at NAPA and they did not have them in stock, but could order them. I think Tractor Supply can get them too. I don't think your WD6 will do very well on gas unless you have these plugs in it. As others said, $7 or $8 each. It's a non standard, low volume plug.
Smitholm
12-11-2003 13:13:30
I've used Champion D-89D, later number is 543, with success. My local NAPA store orders them, next day delivery. They're salty - maybe $6-$7 a shot, but they work. Good luck.
Harold H
12-11-2003 12:10:27
My 1952 service data shows either a AC 18A, or Auto-Lite BT-15, or Champion 49. I don't know what is the modern equivilent of these plugs. Gap is .020-.025.
Harold H
Bob M
12-11-2003 11:00:25
The gas-start diesel uses a special, super extended reach plug with the electrodes sticking a good inch or more beyond the threaded shell. If I recall it's either either a Champion W-89D (7/8" thread) or D-89D (18mm thread).
My local TSC had a few of 'em in stock the last time I was there. Not cheap however - recall they were about $7 each.
The Red
12-11-2003 10:22:38
Since you are not using the spark plugs for very long, I recommend you go with a hotter plug. AC C86 or Champion YD 21 or Autolite 386.
