3688 motor job
jim in ny
12-11-2003 17:31:03
we have a 3688 that we bought a couple yrs ago. had a leaky radiator from day 1 now are paying the price for just running it. lots of bubbles in the rad. would like to get my hands around the neck of the idiot engineer that designed the tin work on that thing. took 3 hrs just to get the radiator out #@#$%$$$$metric %%$$$$$ can just imagine what its going to cost to recore that stupid radiator with the hole in the middle. engine kits not that bad cih dealer quoted me around 1,000
Torque
12-12-2003 17:57:15
 Re: 3688 motor job in reply to jim in ny, 12-11-2003 17:31:03
Unless this engine burns oil or has low compression I would think you only need a head gasket. My IH truck (466) acted as you discribe and a gasket fixed it. But if you got it very hot (needle pegged in the red) for an extended period, you probably took the temper out of the rings.
jim in ny
12-13-2003 05:34:18
 Re: Re: 3688 motor job in reply to Torque, 12-12-2003 17:57:15
like the tractor just fine- to drive that is. but it is a futhermucker to work on.just wish thsy had thought of the flip up hood
Cliff Neubauer
12-12-2003 15:18:34
The forward air flow cooling used on the 88 series didn't work out as well as IH had hoped but it was still works good as long as you keep the area around the radiator cleaned out. There is a small access panel on the left side just behind the radiator you can take off with 4 bolts after removing the side panel to keep it clean. The radiator may not be cheap to recore but any of those big radiator's are expensive to recore. For the engine kit if you have a Navistar truck dealership close you can get their DT-466 overhaul kit cheaper and CIH just gets their kits from Navistar and puts their name on the box. We just put a CIH reman engine in our 5488 for $4,000, a JD 466 reman engine is over $7,000 so yes the IH engines are cheap to work on. Most other companies went to metric long before IH did.
stuart
12-12-2003 09:02:36
anyone who thinks a 88 series is any kind of a tractor are as dumb as a post
colekicker
12-12-2003 10:23:09
 Re: Re: 3688 motor job in reply to stuart, 12-12-2003 09:02:36
The 88 series was one of the most sophisticated tractors the IH made. Although the hood may be heck to get off, it was designed so that heat would be pulled off the block and through the top of the hood. Any true IH fan sees it as the last of the breed before the other company had influence on them. The transmission may not have been the greatest on the market at the time, but they are still great tractors worth spending money on.
Farmallkid
12-11-2003 18:06:57
never heard of a 3688, is it farmall or some other make?
Gibby
12-11-2003 21:14:33
 Re: Re: 3688 motor job in reply to Farmallkid, 12-11-2003 18:06:57
IH product - 113 ponies.. Big boy toy..
