jump starting smta
paul
12-13-2003 05:30:24
Can you jump start a smta off the starter terminal instead of messing arround with the seat and battery box?? Paul.
randy hall
12-13-2003 10:13:02
 Re: jump starting smta in reply to paul, 12-13-2003 05:30:24
you can jump off the terminal at the starter safely. you still have to pull the starter rod to engage the starter on your super mta. on a straight m it would energize the starter directly hooking to the starter.
CNKS
12-13-2003 13:39:25
 Re: Re: jump starting smta in reply to randy hall, 12-13-2003 10:13:02
You are right, I forgot about the different starter design.
CNKS
12-13-2003 08:55:51
I have done it but don't like to because of sparks flying everywhere -- close to carb and gas tank. Remove the cable as soon as it starts, as it will keep spinning the starter otherwise.
NDS
12-13-2003 06:25:27
Yes you can but it is not reccomended because of danger of tractor starting up in gear with you standing beside it. Have seen this happen several times over the years luckily have never seen anyone seriously hurt but have seen property damage.
