Home made Tarctor stands
Kelly C
12-13-2003 12:21:12
third party image
Made these this morning. The cherry picker/ Blocking method was making me feel unsafe.
look pretty nifty
12-13-2003 16:11:38
 Re: Home made Tarctor stands in reply to Kelly C, 12-13-2003 12:21:12
I like those stands. I run large CaseIH tractors and have some older farmalls and CaseIH works on the magnums. I work on the farmalls and when I do split one of mine I borrow a pair of stands from them as they are out back on pallets as they do not use them much anymore because of $60 per hour labor. I purchase all my parts from them exept for used parts. Gotta keep those dealers in the area to survive
Rudi
12-13-2003 14:17:19
third party image
Kelly:
any chance for a drawing for those of us less mechanically inclined?
Kelly C
12-13-2003 15:47:18
 Re: Re: Home made Tarctor stands in reply to Rudi, 12-13-2003 14:17:19
third party image
Here is a close up shot of the bottom.
Just mesure from the top of the frame rail to the ground. I cant remember how long I got mine.
I went to my local welding shop Purchased 2 lenths of 4 inch x 1/4th inch angle iron
2 x 4inch x 4 inch x 1/4 inch plates
2 feet of b7 3/4 inch threded rod
4 nuts
I am lucky my welder has a punch press. Saved me alot of drilling for the holes. I took a 4 inch wide piece of manila folder and traced the hole pattern from the frame rail. He then drew them on the angle iron and put a 5/8th die in the press.
He them just punched out the holes. Took about 1 sec per hole.
I also had him punch 3/4 inch holes in the center of the 2 square pieces.
I dont know what he charged me for the holes and I dont care. Drilling 3/4 inch holes in 1/4 inch steele sucks.
When I got home. I cut 3 inches off the bottom of each piece of angle iron and weled them into a square on the bottom. Welded the 4 inch flat steel onto the bottom. Then welded a nut onto it.
Just take a 3/4 inch bolt and 2 nuts. Put one nut on the bolt and put it into the hole in the bottom plate. Them screw the other nut onto it from the other side. This holds the nut you want to weld center of the hole.
Then cut your 2 foot rod in two.
Insert 1 rod into the bolt now welded to the bottom. Then weld a nut onto the ground end of the rod.
WaLa!!! You have a stand.
Rudi
12-13-2003 16:12:18
 Re: Re: Re: Home made Tarctor stands in reply to Kelly C, 12-13-2003 15:47:18
third party image
Kelly:
Thanks a bunch for the quick response. Pretty good idea. I think I will try it for my Cubs.
Kelly C
12-13-2003 16:24:32
 Re: Re: Re: Re: Home made Tarctor stands in reply to Rudi, 12-13-2003 16:12:18
third party image
I will dubble check the thickness on the angle iron for you. Might be 1/3rd inch thick.
I actually purchased the angle iron a year or so ago. I used that on my H when I did a bolster rebuild.
They were to short for my 400 and could not adjust them. Thats when I got the idea for the plates and rods to make them adjustable. That way I can still use them on my H and 300.
Van
12-13-2003 17:12:48
 Re: Re: Re: Re: Re: Home made Tarctor stands in reply to Kelly C, 12-13-2003 16:24:32
Kelly,
Looks good, now take it to the next level.
I have a two pairs with a adjustable cross bar about one foot from the floor with 4" cast iron wheels on them. They are made from reciever hitch tubing. They slide inside of the correct for size square tubing, each leg has two set screws to lock the adjustment for height and width. Bolt one on each end, adjust width and height and roll it apart. Front one has offset dogleg feet on it to keep a narrow front shiny side up.
Rudi
12-13-2003 17:48:41
 Re: Re: Re: Re: Re: Re: Home made Tarctor stands in reply to Van, 12-13-2003 17:12:48
third party image
Van:
Sounds real good. As Kelly said, any photos and sketches -- way beyond my skill level as well, gonna need some good instructions.
Kelly C
12-13-2003 17:35:37
WHOA!!! there big daddy. You just skipped way out side the lines on my skill level.
Got any photos?
Van
12-13-2003 18:35:06
 Re: Re: Re: Re: Re: Re: Re: Home made Tarctor stan in reply to Kelly C, 12-13-2003 17:35:37
No photos and my digital is feet up, but I may get one from santa (I peeked)
Rick(MN)
12-13-2003 13:50:55
Looks like it should be just the ticket.....
