560 brakes
joe
12-13-2003 15:36:01
the housing is cracked from the opening where the linkage / adjusting rod comes out (rubber boot covers it), to the center hole. both sides are
cracked the same place. see photo posted in Parts and Pieces. should i be concerned???
are the 5 balls that run in holes with a ramp on one end between the brake expander plates lubricated or left dry???
Tom
12-14-2003 05:50:15
 Re: 560 brakes in reply to joe, 12-13-2003 15:36:01
Joe, Don't know how much difference between the 560 brake and the SMTA. I have greased the balls lightly; left them dry and currently using silicone for lubrication. So far the silicone seems to provide the necessary lubrication, prevents rust and corrosion, and does not acccumulate dirt and other foreign material on the ramps and balls. Before applying the (spray on) silicone, I pollished the ramps and balls. The springs are available if they need replacing. Also, remove any burrs on the splines with a file or die grinder. As far as the drums, if your brake action is sufficient, inspect them occassionaly to see if the cracking is progressing. Tom
joe
12-14-2003 09:48:21
 Re: Re: 560 brakes in reply to Tom, 12-14-2003 05:50:15
thanks for the very helpful info.
