460 gas, what to do with it.
earlschieb
12-13-2003 17:28:48
I just bought a 460 gas, it seems to be a 1959 model, since the first 3 digits of the serial number is 161. Does anyone know what the S - Z stands for at the end of the serial number? I don't have a use for this tractor, but the price was right on it, it is a narrow front, has the Fast Hitch on it, and really good matching rear tires on it. All the sheet metal is decent on it also, T/A is supposed to be good, and it has the triangle with the serial number showing that it had the updates installed in the rear end. I haven't had a chance to drive it yet, got to go get it in S.W. Ohio.
Rich
12-13-2003 20:06:53
 Re: 460 gas, what to do with it. in reply to earlschieb, 12-13-2003 17:28:48
I noticed you said you dont have a use for it . Would you consider selling this tractor?? I am looking for one to convert into a pulling tractor!!
earlschieb
12-14-2003 06:11:21
 Re: Re: 460 gas, what to do with it. in reply to Rich, 12-13-2003 20:06:53
Might be interested Rich, it is bigger and newer than I normally mess with, you can email me at the above email address.
CNKS
12-13-2003 17:43:35
S means "TA with provision for 540 rpm PTO", Z means "hydra touch power supply (with 17-gpm pump)"
earlschieb
12-13-2003 18:40:17
 Re: Re: 460 gas, what to do with it. in reply to CNKS, 12-13-2003 17:43:35
What is the difference in the Hydra Touch, over the regular hydraulics anyway? I know the difference in the 17 gpm pump, and the 11 gpm pump, but what does the hyra touch mean, or do?
CNKS
12-13-2003 19:15:45
 Re: Re: Re: 460 gas, what to do with it. in reply to earlschieb, 12-13-2003 18:40:17
I'm not the 460/560 expert, but it's just an improved system, someone else will have to provide the details. But, I think the big change in hydraulics camr with the 300, 400 series where there were 2 or 3 valves instead of one. On the 460/560 there was a knob or lever that selected either one or two way cylinders.
earlschieb
12-13-2003 20:05:31
 Re: Re: Re: Re: 460 gas, what to do with it. in reply to CNKS, 12-13-2003 19:15:45
Thanks, that is what that mine has, and my 460 utility didn't have I don't think.
CNKS
12-13-2003 17:46:47
Make that "540 Independent pto", an R code designates the transmission driven pto.
