Farmall H Super H use same cyl head???
Rich
12-13-2003 20:13:06
I am in the process of turning a Farmall H into a Super H .Does any one know for sure !!!!! if the cylinder heads are interchangable ????
42FarmallH
12-14-2003 07:28:54
 Re: Farmall H Super H use same cyl head??? in reply to Rich , 12-13-2003 20:13:06
You can't turn an H into a Super, and if you think putting oversize pistons in the engine makes it a Super, think again.
Please don't put super decals on it either, there are already enough fakes out there to keep everyone busy...
justin
12-14-2003 07:21:00
They will interchange, but only with flat top pistons. If you try putting a H head on a Super H with step head pistons, the pistons will hit the head.....
rustyfarmall
12-14-2003 07:10:46
Whatever head fits one will fit the other.
Dave
12-14-2003 09:04:26
 Re: Re: Farmall H Super H use same cyl head??? in reply to rustyfarmall, 12-14-2003 07:10:46
On tractors this old you sometimes find exceptions but on most i see the main difference
between H & SH heads is on SH the combustion chamber is sloped on side oppisite spark plug
and H is not. As pointed out in previous follow
up some pistons will hit H cylinder head.
