? on MD and A
Ty
12-14-2003 08:53:19
On a A you can push the clutch pedal in and doesn't do anything. There's pressure on the pedal. It's been sitting inside for a while. There not my tractors and he thinks that the throw out bearing isn't great. on the MD runs great on gas and on diesel it idles slow and fast great but sputters in between. Full throttle under load it runs like a mad man. Dynos 52hp. Good pump pressure redone nozzles any ideas?
BIG JOHN
12-14-2003 10:13:36
 Re: ? on MD and A in reply to Ty, 12-14-2003 08:53:19
On the A question. - The clutch disc has stuck to the flywheel. Usually you can start it in gear and drive it with the clutch depressed, changing the speed and using the brake, and going up hill and it will break loose.
GOOD LUCK
