H PTO question
'43h
12-14-2003 15:16:57
The PTO on my H appears to engage and disengage properly, but when disengaged, it continues to rotate at a very slow speed, maybe 20-30 rpm. I know that the previous owner ran a brush hog with it, so it is (was) working under load.
How big a problem is this and what is involved in fixing it...thanks.....
42FarmallH
12-14-2003 17:15:19
 Re: H PTO question in reply to '43h, 12-14-2003 15:16:57
I rebuilt mine and it does the same thing until the grease in the rearend warms up. Never turns when something is hooked up to it, or can stop it by hand easily. Normal stuff...
rustyfarmall
12-14-2003 15:36:20
It is being driven by the heavy oil in the rear end. You should be able to stop it with your hand. This is normal, especially in cooler weather.
'43h
12-14-2003 15:42:18
 Re: Re: H PTO question in reply to rustyfarmall, 12-14-2003 15:36:20
Thanks! That's the kind of fix I like...relax and wait for spring...
CARROLL LAY
08-27-2006 06:12:45
 pto will not work when engaged in reply to '43h, 12-14-2003 15:42:18
I HAVE A 1952 FARMALL CUB AND MY PTO WILL NOT TURN ON AT ALL WHEN ENGAGED. IT WILL FREETURN BY HAND ONLY, NOT ANY TIME THE PTO IN ON. IS IT HARD TO REPLACE / FIX? WHEN I PULL IT OUT, WILL I MESS UP AND NOT BE ABLE TO PUT IN BACK IN PLACE EASY? THANKS CARROLL LAY IN SC
calay@mindspring.com
