Farmall H timing with a distributor
Mark
12-14-2003 15:17:33
Could anybody tell me how to time a farmall H with a distributor? My book only covers magneto timing.
Thanks
Mark
Gary-Miss
12-14-2003 15:44:36
 Re: Farmall H timing with a distributor in reply to Mark, 12-14-2003 15:17:33
Same difference as a magneto. The plugs can't tell the difference. The only thing is, the mag has an impulse that you have to turn past, then, back up to. Get the timing mark you want, turn the ignition switch on, rotate the distributor in the SAME direction as the distributor shaft turns, then, real slowly rotate the distributor AGAINST the direction of rotation until itsparks. Lock it down. You will probably have to do this several times before you catch it at the exact moment it sparks (the points open)
Mark
12-14-2003 16:20:41
 Re: Re: Farmall H timing with a distributor in reply to Gary-Miss, 12-14-2003 15:44:36
There are three notches on the crankshaft belt pulley. The first mark in TDC, what are the other two.
Thanks
Mark
Steve - IN
12-14-2003 17:35:30
 Re: Re: Re: Farmall H timing with a distributor in reply to Mark, 12-14-2003 16:20:41
Mark,
You should find a TDC, a static timing mark, and a max timing mark on the pulley. The static and the TDC mark should be fairly close together, and the max timing should be 30 or 35 degrees from TDC (memory fails, my service manual is out in the barn, and it's COLD!).
If you're starting from having pulled the distributor, turn the engine to the TDC or static timing mark -- they should only be 4 or 5 degrees apart -- pull the #1 plug (farthest front) ground it to the tractor and move the distributor until you see the plug spark. That should get it timed well enough to start it.
If your H is still + ground or 6 volts or both, you're going to need an external 12v battery to use with your standard automotive strobe timing light. The other hassle is that with a 50+ year old distributor there's going to be enough slop that you can see your dynamic timing jumping a few degrees either way while you're using the strobe. If it is steady, crank in 3/4 to 80% throttle and move the distributor until the light fires showing the pointer lined up with the max mark.
If you don't want to go the spare battery / trust the distrubtor route - set the throttle at 20% - 40% and move the distributor until you hear the fastest idle speed, then back it off and tad, bolt down the distributor then take it out and try the engine under load, listening for pre-igntion. If it sounds good, you've gotten 95% of the result for half the effort. If you hear a ping, retard it a little - and generally err on the side of too much retard to be safe.
Anyway, either way, it shouldn't take you long to get the old H purring like a kitten - which is the real payoff. Good luck, and have fun with it.
Mark
12-14-2003 18:45:37
 Re: Re: Re: Re: Farmall H timing with a distributo in reply to Steve - IN, 12-14-2003 17:35:30
Thanks for all the help.
