SUPER C distributor info
JWH
12-14-2003 19:58:41
I started to gather parts for a dist.rebuild. I got a new shaft on ebay for 5 bucks,still need springs & bushing. Anyway I haven't taken the dist. off yet but I was looking at the new shaft & noticed there's no hole in the end to pin the gear on. What holds the gear on?
Stan(VA).
12-14-2003 20:34:59
 Re: SUPER C distributor info in reply to JWH, 12-14-2003 19:58:41
If it's like the one I did a few years ago, you need to drill one. The drive gear on the old one should have a pin holding it on that you will need to tap out, then remove the gear and use it as the guide to drill the new hole in the shaft.
Stan(VA).
JWH
12-15-2003 18:53:10
 Re: Re: SUPER C distributor info in reply to Stan(VA)., 12-14-2003 20:34:59
Thanks Stan, Jim
