Just got 47 Farmall A
Tom Williams II
12-15-2003 07:14:10
The deal and the tractor were just too much to pass on. I know it doesn't have hydraulics but does have a manual lift and some sort of hitch.
Can anyone please tell me the differences between it and the lift on a Ford or Massey? Can all sorts of implements be found for it?
Is this a good useful tractor for just cutting, bush hogging and a little cultivating of flower beds and stuff??
Any help would be appreciated.
Tom
CNKS
12-15-2003 07:44:54
 Re: Just got 47 Farmall A in reply to Tom Williams III, 12-15-2003 07:14:10
Unless you like modifying implements from other tractors, only the ones made specifically for the A will fit. You can use it for whatever you can make work, IH made mounted plows, cultivaters, planters, etc for it. It was generally used mainly as a cultivating tractor, although some farmers used it as their only tractor. You can get Woods belly mowers for it, also IH if you can find one, but because there is no rear hitch the bush hog type are usually pulled.
