super a oil pan
ovil winburn
12-15-2003 07:51:07
I'm stripping this 1954 super a down to ground zero to restore and the oil pan doesn't want to budge. it looks like there is a retaining plate in two pieces around the flange. may have been cut previously. is that what is holding it on, i can't see that well and not much else is any good either at this present old age but i don't want to give up. i don't want to damage something for which i can't replace, i'm sure this is a simple procedure but i would appreciate someone taking a minute to respond. ovil in ocala, florida
ovil winburn
12-16-2003 05:20:45
 Re: super a oil pan in reply to ovil winburn, 12-15-2003 07:51:07
thank you sir, worked like a charm. good to know what your're doing before putting a hammer to it.
Daniel
12-15-2003 09:20:33
The retaining plate is made in mutiple pieces so thats ok. Are you sure you got the bolts across the front and BACK. You may need to remove the half-moon inspection plate from the lower half of the bell housing to see them. If you have all the bolts out try tapping a stiff puddy knife in between the block and the pan it should come you but you may have to work all the way around it with the puddy knife. Also be sure to put sealer on the bolt threads when you put it back because some of them go through and will drip oil.
