Oil filter o-ring: wrong one, or operator error?
Darren in TN
12-15-2003 08:52:14
Howdy, all.
I could have sworn I posted this already, but I can't find it now. When I changed the oil filter in my Super A I also replaced the o-ring with the one provided with the cartridge. I did a thorough job of cleaning out the old o-ring residue out of the groove. However, it seems to seep oil when the tractor is running. Did I install it wrong, over-tighten, or do these always seep a little?? (The groove is triangular, whereas the o-ring is square in cross-section... is that right??)
Thanks again,
Darren
Jake
12-19-2003 17:59:39
 Re: Oil filter o-ring: wrong one, or operator erro in reply to Darren in TN, 12-15-2003 08:52:14
Triangular groove? NO NO NO. Sounds like you still have the old ring stuck in the groove. The groove is square to match your new 0-ring. Those old rings can be very hard as another poster mentioned.
I"ve noticed the after market oil filters always come with the new seal ring, the OEM filters do not and you are forced to buy it at extra cost if you go that route.
John Lolli
03-07-2005 07:46:42
 Re: Re: Oil filter o-ring: wrong one, or operator in reply to Jake, 12-19-2003 17:59:39
How deep is the groove supposed to be in the oil filter housing. Mine is also leaking and there may be extra gaskets.
Paul Shuler
12-15-2003 14:55:42
I had a leak once, cleaned it all up real good. put in another o-ring and it still leaked. Took a small flat screw driver and started going around the grove and dug out three old o-rings. When it's cleaned out the o-ring fits nice down it the grove and it won't leak.
rustyfarmall
12-15-2003 12:29:57
You guys that never change the o-ring gasket are asking for trouble just like Darren has encountered. Sooner or later, the old gasket will leak, and then you will have a lot of fun trying to get that hard as iron rubber o-ring out of the groove. Doesn't the new filter come with a new o-ring each time?
Ben in KY
12-15-2003 12:52:07
 Re: Re: Oil filter o-ring: wrong one, or operator in reply to rustyfarmall, 12-15-2003 12:29:57
The Napa Gold filters come rith rubber sealing ring. I replace the seal with each filter change, no leaks :)
Red Dave
12-15-2003 10:51:06
Sounds like you didn't get the groove clean. The O-ring and the groove are square in cross-section.
I always replace the O-ring on those engines when I change the filter. Haven't had a leak yet.
smirkey
12-15-2003 10:00:21
i've changed a lot of filters on our A, super H, and 450. never changed the o-ring ever. many years i didn't think it even had one.
matt_mn
12-15-2003 09:52:19
I have an H and it uses a square packing/square cut ring also. In response to the earlier post of maybe an old one still in there. I think it is a definite possibility. I would take it apart and take a small screwdriver or even better a o-ring pick and scratch around in the groove. A metal tool scratching on metal has a definite sound and feel. Good luck. Your new ring that came with the filter should fit and seal.
moonlite
12-15-2003 09:46:29
I seldom replace the "O" ring. A new one seems to be more likely to leak than the old one is.
Dave_Id
12-15-2003 09:12:06
I agree with Bob, You may still have another seal in the square groove....
Bob
12-15-2003 08:55:04
I could be wrong about this, but I don't recall the groove being "triangular". You may still have an old, hard gasket down in the groove from a long-ago filter change.
Darren in TN
12-15-2003 09:37:42
 Re: Re: Oil filter o-ring: wrong one, or operator in reply to Bob, 12-15-2003 08:55:04
Oh, boy... That would definitely explain it. I'll get a strong light on it and see what I can find.
Thanks, guys.
Darren
Mitchell Pool
12-15-2003 09:41:14
 Re: Re: Re: Oil filter o-ring: wrong one, or opera in reply to Darren in TN, 12-15-2003 09:37:42
On my m i didn't put the o ring under the cover it did not fit right no leaks.
