backfire though carb.
smcIN
12-15-2003 18:32:12
I am repainting my 1940 B . So as I get things painted I am putting it back together. Well I have it together enough to run and I and it keeps backfiring though the carb. I rebuilt the carb . It runs but will backfire. Any suggestions to solve this? I know I am looking right at the problem but can't seem to get it. Thanks in advance.
brad l
12-16-2003 14:50:24
 Re: backfire though carb. in reply to smcIN, 12-15-2003 18:32:12
I know its 1,3,4,2 on an H
gene b
12-16-2003 03:00:08
Better get the wires on correct. Also did you paint the wires and spark plugs as the paint can ground them out.
smcIN
12-16-2003 18:12:36
 Re: Re: backfire though carb. in reply to gene b, 12-16-2003 03:00:08
I replaced all of plug wires, cap, rotor, and cap on the mag. I think that they are right but I will check to make sure. Also I replaced the head gasket before painting so it might be the valve need to be adjusted. Thanks I will let you know what I find. I will get back to this weekend.
Mark
12-15-2003 20:24:50
Sounds like the problem i had with my wd 6. Had #3 and #2 plug wires crossed.
ken
12-15-2003 19:09:54
as you are repainting you didn't by chance switch a couple of plug wires?
old
12-15-2003 18:42:20
Well your timing could be off a little.
You could have a valve that isn't seating/set right tappet to tight.
Or it could be that it is running lean. Hope this gives you some help
