Order Farmall Cub Parts Online
Farmall Cub Snow Plow/Grader Blade ??
Fast Freddie
12-17-2003 06:35:03
Are all Cub front mounted snow plows able to be mounted as a mid mount grader blade?Thanks!
George Willer
12-17-2003 10:33:04
 Re: Farmall Cub Snow Plow/Grader Blade ?? in reply to Fast Freddie, 12-17-2003 06:35:03
Freddie,
Yes, for IH blades on regular F-Cub, but not on Lo-Boys. On the Lo-Boy there isn't enough height to lift it in the rear position.
George Willer
Rudi
12-17-2003 06:54:27
third party image
Freddie:
Ifn you got to the link below, check under Cub Implement Manuals, you will find the manual for the Cub 54 andc 54-A Blades. I think they are pdf's but can't remember off-hand what formats I uploaded.
It should answer all of your questions on the blade.
Haas
12-17-2003 06:40:06
Well, probably not all. But I think all that IH made for the Cub were like that. A few different parts needed for each location, but those were included, but tend to get lost over the years, as usually the blades are only used in one position.
