Super A: 6 Volt to 12 Volt
Paul G
12-17-2003 06:38:29
An old farmer told me to stop fussing with a 6 Volt and but a resister for $10 and change to a 12 Volt. Is it that simple?
Steve
12-17-2003 14:49:15
 Re: Super A: 6 Volt to 12 Volt in reply to Paul G , 12-17-2003 06:38:29
Hugh is right. The Super A was designed to work on 6 volts and will. Mine starts excellent on 6. Just get the electrical system up to snuff and it will work fine. Of course the engine needs to run correctly to begin with. I switched my 300 over to 12 volts and really spent that money for no real benefit. It starts great either way.
Hugh MacKay
12-17-2003 15:59:24
 Re: Re: Super A: 6 Volt to 12 Volt in reply to Steve, 12-17-2003 14:49:15
Steve: I supose I am starting to sound like a broken record, but your right on the 300, I once started my 6 volt 300 at -40F with no assists of any kind.
I currently have a 6 volt Super A and 12 volt 130 and a 140. I have not had the 140 in cold weather as yet. I will however guarentee my 6 volt Super A will out start my 12 volt 130 anyday, especially when cold.
Hugh MacKay
12-17-2003 09:36:55
Paul: If it isn't charging 6 volt, it probably will not charge 12 volt. It it is charging and you want a real fix, spend your money on a set of 1 gauge battery cables with soldered on ends and run the ground strap to a casting rather than sheel metal.
Steve - IN
12-17-2003 07:41:18
Paul,
It will run that way, but it probably won't charge and don't use the lights. To charge the battery, you'll at least have to change to a 12 volt regulator, and don't forget to change to 12 volt bulbs if you plan to use the lights.
