stuck 230 motor
sarg
12-17-2003 09:26:38
help 1, jacked leftrear in high gear nothing 2, push in clutch and tire will spin 3, jack up both tires in high , nothing 4, lock clutch down and one tire will spin frontwards the other backwards any and all help is needed ive heard to use every thing from pb blaster to murphys to olive oil would have to send the hole tractor off to get it broken down ,last resort thanks
sarg
12-17-2003 14:24:09
 Re: stuck 230 motor in reply to sarg , 12-17-2003 09:26:38
ok guys lets do this i wont to hear them all let me know what you use and what you have heard of being used if i get enough ill put it in my book
rustyfarmall
12-17-2003 15:11:39
 Re: Re: stuck 230 motor in reply to sarg , 12-17-2003 14:24:09
I have tried just about everything I ever heard of, and I will tell you that there is no magic potion. Some people will tell you that their solution is the only way to do it because it freed an engine in only one or two days. Apparently, that engine had not been stuck for very long. Twice now, I have ended up breaking the pistons to get them out, after using the magic potions, and allowing several weeks to let it work. The cheapest and most effective product is plain old diesel fuel and brake fluid, mixed about 50/50.
Farmalldan
12-17-2003 11:43:49
Sarg,
Make sure the starter is not jammed in the ring gear. Remove starter to make sure.
Dale
12-17-2003 10:48:03
The best thing you can use is KROIL,Dale
