D264 Gas start Diesel Engine
Eric
12-17-2003 11:04:56
I have a 1956 W400 And a 1953 SWD6 both with the D264 Gas start Diesel my question is about the diesel injection pumps they both look similar but the W400 has a IH mould on the casing the SWD6 has an A mould on the casing What is the diffrence, between these pumps thanks in advance Eric..
Farmallkid
12-17-2003 14:49:47
 Re: D264 Gas start Diesel Engine in reply to Eric , 12-17-2003 11:04:56
I don't know to much about this subject, but i was wondering if you could send me a picture of the w400.
Farmaller
12-17-2003 13:49:16
The IH pumps are better because you can adjust more fuel at the top of the plunger. All pumps are interchangable from the MD through 650D.
Geoff
12-17-2003 12:05:32
The 400 has a type B pump (they have the IH logo) the SWD 6 has the type A pump. Both pumps are IHC built and can be interchanged with a bit of plumbing.
E J
12-17-2003 11:36:32
IHC used two types of pumps their own IH or the Bosh.Not much dif. two different builders.
John
12-17-2003 11:53:16
 Re: Re: D264 Gas start Diesel Engine in reply to E J, 12-17-2003 11:36:32
E.J Do you know if the D264 diesel was also used in the 1948 M.D models?
Geoff
12-17-2003 11:58:40
 Re: Re: Re: D264 Gas start Diesel Engine in reply to John, 12-17-2003 11:53:16
The '48 MD had a 248 motor
