Water pump assembly, Super H
gauger
12-18-2003 14:36:49
On the H / Super H water pump, is the rear pulley flange (the one that has the generator pulley as part of it) pressed onto the hub? The parts book show's it as a separate piece and I would like to get it off so I can remove the adjustable pulley flange that screw's onto the hub.
Red-Ed
12-18-2003 17:03:24
 Re: Water pump assembly, Super H in reply to gauger, 12-18-2003 14:36:49
Yes it is pressed on. I replaced the adjustable 1/2 of the fan pulley a year ago on my SH. I took the assembly to my IH service man and he pressed it off and back on for me in about 5 minutes. The best part is he didn't charge me anything. Good luck.
riverbend
12-18-2003 20:25:50
 Re: Re: Water pump assembly, Super H in reply to Red-Ed, 12-18-2003 17:03:24
On my H's water pump, the rear flange was held in place with a pin. I was able to push the rear flange off with the adjustable one. The bearings and sleeve had to come out of the hub before I could drive the pin into the center.
Greg
