Questions on 300U rebuild
Kit Gage in VT
12-18-2003 14:51:47
I got the cracked head back, fixed, leveled and new intake valves. Also, rebuilt the oil pump which was ailing. The head gasket says use sealer and torque to specs. I bought gasket sealer but am unsure as to where to put it - around each opening? - around the cylinders? - I assume both sides. The machine shop said I should see some improvement as the intake valves were shot. Great project! Thanks,
Kit
Kit Gage in VT
12-19-2003 04:40:40
 Re: Questions on 300U rebuild in reply to Kit Gage in VT, 12-18-2003 14:51:47
Thanks Zak & CNKS.
Zak
12-18-2003 20:07:50
I'd go with a light bead around each opening in the head gasket EXCEPT for the fire rings. Just a light smear around each hole oughta make sure you have no leaks. I learned this the hard way. Zak
CNKS
12-18-2003 18:01:15
Many opinions on this, mine is a light coat of copper coat on the whole thing.
