Just wondering ------- M.D.
John
12-19-2003 10:56:13
Would like to know when Farmall came out with glow plugs. Also if all the heads on say the 1947 -1956 deisels were the same and interchangeable with a gas start up being used. Thanks for any info.
RN
12-19-2003 17:06:19
 Re: Just wondering ------- M.D. in reply to John, 12-19-2003 10:56:13
MD gas start to diesel heads interchange? Possible with warning- about 3 different casting designs, last design needed a bit of work to replace first design- bolt hole larger and a bit of water jacket gasket adjustment?, fuel injector also upgraded- needed shimming? Brothers shop did some replace/upgrade head years back, needed a bit extra work, gripe about billing. RN
Farmaller
12-19-2003 12:58:55
Heads do not interchange from gas-start to glow plug heads.
42FarmallH
12-19-2003 11:58:14
Glow plugs started with the 460, 560, and 660 diesel engines on tractors in 1958. They were also used in crawlers.
I don't know if the gas start diesel heads are interchangeable between years, sorry.
