to rebuilder smta ta
PAUL
12-19-2003 11:27:13
when you mentioned throw out bearing as possible cause to low side gear noise i thought i would let you know that you can hear rattling type noise when engine running on low side in netural also quiet on high side running in netural ta throw out or main throw out?? thanks paul
Chuck's Repair
12-19-2003 19:34:37
 Re: to rebuilder smta ta in reply to PAUL, 12-19-2003 11:27:13
TA throw out bearing.Also check to see if the TA linkage is not adjusted too short as this will cause the TA throw out bearing retainer to come in contact with the rotating TA pressure plate and make a rattling noise.Try moving the TA handle forward slightly and see if the noise doesn't stop.
paul
12-20-2003 17:53:03
 Re: Re: to rebuilder smta ta in reply to Chuck's Repair, 12-19-2003 19:34:37
Chuck's repair.Took your advise moved the handle noise did stop but went into high side good thought, so i spent the rest of the day running compression test.I was suprised at 122-125-120 121 lucked out on engine.Then built splitting stands.Drained trans still dripping only got about 8 gallons and white as cream. Mabe thats the cause of gear noise. Thanks for your advise. Paul.
Chuck's Repair
12-20-2003 19:16:46
 Re: Re: Re: to rebuilder smta ta in reply to paul, 12-20-2003 17:53:03
The milky Hy-Tran is water.IH has a boot available that you can install over the gear shift lever to keep rain water from running down the shift lever and into the transmission.I don't remember the part number or whether it is still available.It has been a number of years since I last installed one.If the Hy-Tran is as milky as you say you may have to change it a couple of times to get all the water out.It is best to drain the Hy-Tran after you have worked the tractor hard and the transmission is hot.
paul
12-21-2003 05:57:15
 Re: Re: Re: Re: to rebuilder smta ta in reply to Chuck's Repair, 12-20-2003 19:16:46
Chuck's repair. I hace been in auto service for years and wonder why you cannot use dextron to replace hy-trans we have been using dextron for years in manual transmissions to ease shifting effort and grinding.when i am done with repairs this tractor will be used for antique tractor pulling stock.no long hard work under load.i have also heard that hy-trans will cause seals to leak will dextron do the same?? Paul.
