Order Farmall Cub Parts Online
Clutch on Cub Powerunit
Red Tom
12-19-2003 13:05:19
I have a Cub powerunit from a baler with right angle drive. What kind of clutch would have been on this for stationary work and where could I find one? Something like a Rockford?
Gary-Miss
12-20-2003 15:13:42
 Re: Clutch on Cub Powerunit in reply to Red Tom, 12-19-2003 13:05:19
I have a cub power unit with direct drive, old enough that it does not have a starter or a place for one. The motor is stuck. I took it in on trade for some work I did and I would like to get rid of, either a trade or a sale. I'll be glad to measure the clutch for you, also.
Red Tom
12-19-2003 16:38:12
Yes I'm sure I have a Cub and I know what kind of drive I have now. I said I was looking for a clutch like a rockford to put on it instead of the right angle drive I have now.
gene b
12-19-2003 19:33:44
 Re: Re: Clutch on Cub Powerunit in reply to Red Tom , 12-19-2003 16:38:12
If that is the case i would tear it down and see if the flywheel is drilled and tapped for a pressure plate then a rebuilt clutch assy will get you going call 1-888-828-3216 for parts
George Willer
12-19-2003 21:07:43
 Re: Re: Re: Clutch on Cub Powerunit in reply to gene b, 12-19-2003 19:33:44
The power unit has a much different flywheel. You will have to replace it with one from a tractor. Three Cubs that live here have had that conversion. All are using a Rockford clutch.
George Willer
George Willer
12-19-2003 16:26:05
The Cub power units used on 50T balers after 1947 didn't have clutches. They used a belt idler on the output for a clutch. The drive was direct from the engine to the output pulley. Look carefully and I think you will find the place for the crank in the center of the pulley.
I don't know if the Continentals used previously used the same system but I think so.
George Willer
gene b
12-19-2003 15:07:59
Are you sure that you have a CUB power unit lots were CONTINETAL better check they even had ZENITH carbs and I-H mags there should be a tag on the MAG side.
Rudi
12-19-2003 14:27:16
third party image
Tom:
Go to the link below. There are manuals on the balers which describe the power units. There are some other manuals that may relate to the power units as well.
I do know that I have a couple of manuals still to post that are on the U1 and U2 power units. These are parts manuals however.
Hope this helps some
