What Wide front would be better
Paul G.
12-19-2003 14:31:23
I have an M and had boughten a schwart wide front for it but today I found a factory wide front with the tie rods in front. I have heard that the factory one steers hard but I bought a Char-lynn power steering set up. So I guess my question really is what front would be nicer to have on this tractor? Money isnt the problem I am in the schwarts cheap and can pick up the factory fairly cheap.
Brian in MO
12-20-2003 11:41:09
 Re: What Wide front would be better in reply to Paul G., 12-19-2003 14:31:23
Paul, I think it depends on the use of your tractor. The shwartz is a heavier made front than the old IH with the tie rods out front, but if the tractor is just for shows and parades and light work the IH front is original and will look good. Brian
Kelly C
12-19-2003 20:10:21
I suggest you buy both. Use the swartz on your M then clean up and paint the IH one and sell it for more than you paid for both. = free wide front.
BIG JOHN
12-19-2003 17:19:33
I have both one on an M and the other on a SMTA. I think that the Schwart looks better than the IH. I really can't see any difference in the way they work.
old
12-19-2003 16:04:26
I would think the factroy would be better but don't really know. But which ever one you don't use you can send it may way I need one one my 450
Jon
12-19-2003 16:55:54
 Re: Re: What Wide front would be better in reply to old, 12-19-2003 16:04:26
I would recomend the IH widefront I have an M with the IH wide front with tie rods out front and the charlyn power steering and i love it. It is very strong and dependable.
Zak
12-19-2003 19:07:07
 Re: Re: Re: What Wide front would be better in reply to Jon, 12-19-2003 16:55:54
I'd think that it all depends on your 'goal' for the tractor. If you're just fixing it for yourself to use orputter around with, you've already got (I think) the Schwartz. If you're attempting (or might in the future) to go 100% factory, then go with the IH. Steer-ability is sort of out the window once you introduc power steering, I would think. I'm putting a schwartz WF on my 300 this weekend (if all goes well) as that's what I was able to find and at the right price. Had it been an IH unit, I'd have bought that. Of course, I'm not a stock restorer, just a fixer-upperer so that's my two bits. Zak
