fast hitch on 706
Mitchell Pool
12-20-2003 17:53:57
My friends uncle bought a 706 and it has a fast hitch on it, i thought it would have a 3-point hitch on it, but i haven't looked real close at these tractors, since i have all letter series farmalls. He was wondering if there is some kind of ends with the 3-pt hitch balls in the end, that you could slide into the fh hook-up for a semi mount plow.
Use good adapeters
12-20-2003 19:19:21
 Re: fast hitch on 706 in reply to Mitchell Pool , 12-20-2003 17:53:57
The 2 point hitch pulls from the best place on the tractor "under the belly" look where the 3 point hooks to on the rump!! Good converter prongs will do just as good. I have a pair of ones that are about a inch and 1/4 wide and are really good. not hard to hook up to because they have a notch on the top and a clip bolts on with a 5/8 bolt and they work really well.
Jim
12-20-2003 19:03:59
Forgot to not hide my e-mail address.
Jim
12-20-2003 19:03:02
Yes, I have a pair I would sell. E-mail me and let me know how to contact you and where you are located.
BIG JOHN
12-20-2003 18:10:40
I have a 706G with a fast hitch.
Yes you can get a casting to replace the plate just above the PTO that will connect the third member of a 3 point hitch. The arms come in many different designs with the ball ends.
Or you can purchase a 3 Point adapter that is a complete one piece that just slips into the 2 point hitch.
There are several options for you to consider.
GOOD LUCK
