Hey pcy==,rear oil seal tool question
Vern
12-20-2003 19:03:56
You said awhile back that you made a tool to install the rear main seal on the IH 1066 tractor,and I can't find a tool and thinking about making one like you did,is there any way that you could post a picture of it? That would help alot. Thanks and hope you get this message.
Thanks pcy
12-21-2003 19:17:01
 Re: Hey pcy==,rear oil seal tool question in reply to Vern, 12-20-2003 19:03:56
Thanks for the information,I am going to try it seems like it should work as good as the factory tool.
p-c-y
12-21-2003 06:53:36
we are not set up for pictures , its real simple , just a flat pieasa steal with four of the flywheel bolts holes drilled in it, it is like 8 inch by 8 inch 1/2 inch thick, 3/8 would work fine, take the flat piece put the seal flat against it put the 4 bolts in the crank , pull them up flush, back them off put the plastic ring that comes with the seal on the seal and tighten the bolts again, the plastic ring will pushthe seal to the correct depth, real simple and cheap,works great
Chuck's Repair
12-20-2003 19:22:24
They are available from Hy-Capacity in Humbolt,IA if you don't want to make one.
