Order Farmall Cub Parts Online
plastigaging my rod bearings 1951 cub
john
12-21-2003 05:54:47
after getting my crank back from the machine shopI am plastic gaging my rod bearings on the number 2 and three rods the clearance on one side is one and three quarters thousands the other side is three thousands my book says I need 2-3 thousands the number 1 and 4 bearings are 2 thousands all the way across the journal is this bad or not now what thanks for your help john
mike
12-21-2003 06:36:13
 Re: plastigaging my rod bearings 1951 cub in reply to john, 12-21-2003 05:54:47
Sounds like you may have a couple of bent rods. To be sure check the crank journals #2 & #3 with a mic to be sure the journals were correctly machined. A good machine shop can check the rods. Good Luck Mike
john
12-21-2003 09:29:56
 Re: Re: plastigaging my rod bearings 1951 cub in reply to mike, 12-21-2003 06:36:13
thank you Mike the journals are fine you must be right
