F-30 or W-30 engine oil capacity?
Jim Bannon
12-21-2003 21:15:38
I was wondering if anyone could tell me the engine oil capacity of an F30 or W30 and also if there is a way to idle the engine down. Any help would be greatly appreciated. Thanks
Nebraska Cowman
12-22-2003 02:54:12
 Re: F-30 or W-30 engine oil capacity? in reply to Jim Bannon, 12-21-2003 21:15:38
It hold 7 quarts. When you get a hold of the little lever at the front of the throttle tube, lefthand side just behind the fan, (don't get your fingers caught) can you slow it down? There is and adjustment on the governor spring or something could be stuck.
Old Farmall Dave
12-23-2003 22:57:23
 Re: Re: F-30 or W-30 engine oil capacity? in reply to Nebraska Cowman, 12-22-2003 02:54:12
Here is a thought, but a bad thought. I had the same problem with the idle on an F-20..turned out to be a manifold leak (rust holes in the intake part). Might want to check into that.
