oil capacities
david palmer
12-22-2003 16:26:40
I need to know how much lube to put in a 1947 A. it has no hyd. what type do i use 90w or 30w. also do i put it in the pto and trans how much in each or do they feed each other.
Hugh MacKay
12-22-2003 18:10:00
 Re: oil capacities in reply to david palmer, 12-22-2003 16:26:40
David: Crank case should be 5 quarts, I suspect that is with filter change, either 30W or 15W-40.
The transmission does feed pto and is 5 quarts 90W. Each rear axle drive takes 3 pints 90W as well.
david palmer
12-22-2003 18:40:33
 Re: Re: oil capacities in reply to Hugh MacKay, 12-22-2003 18:10:00
thanks Hugh, I bought this tractor from a fellow workers wife. he passed away. His wife wanted to sell it. I want to it back to original condition since he bought it in 1951. thanks again
