farmall 504 hydrolics
dale(la)
12-22-2003 19:04:39
My dads 504 hydro pump is makeing a wineing nose and the lift is real slow.I checked the fluid level at the pluge and it is full.just wondering what could be wrong.Thanks for any advice.Merry Christmas to all!
dale(la)
12-23-2003 17:08:36
 Re: farmall 504 hydrolics in reply to dale(la), 12-22-2003 19:04:39
Thanks for all the response.I was not aware of a filter.I will check it out.Thanks again
dale(la)
12-23-2003 17:06:13
Ben in KY
12-23-2003 11:44:43
Change/clean any hydraulic filters. Also the fluid could have water in it. Does it look milky ? I Had quite a bit of whine in my front pump on my 444. Changed the fluid and it worked much quieter and better.
KL
12-23-2003 04:35:36
I would start with changing the filter. Hopefully it is clogged up and starving the pump. Mine did something similar but it was low on fluid.
KL
12-23-2003 04:31:00
tom
12-23-2003 04:08:42
i have a 504 that i am parting out, email me if i can help you out
