303combine
jeff
12-23-2003 06:38:28
is the engine in a 303 combine the same as a 460 if so does any one have a460 with a bad motor they want to part with
Chris Mastin
12-23-2003 19:48:01
 Re: 303combine in reply to jeff, 12-23-2003 06:38:28
I have a complete C-301 that will fit in a 460. If interested you can E mail @Chrismastin@aol.com
RPM
12-23-2003 09:08:33
Yes & no, early were a BD220, later was C221, same as 460 but no sleeves, 303 that had front platform edge red was BD220, also rear straw hood emblem was 303 in a circle decal, later had white paint on lower front cab or platform and 303 was flat on rear hood, these were usually equipped with a rotary radiator sieve screen.
jeff
12-23-2003 10:40:02
 Re: Re: 303combine in reply to RPM, 12-23-2003 09:08:33
how can i know for sure
RPM
12-23-2003 14:43:17
 Re: Re: Re: 303combine in reply to jeff, 12-23-2003 10:40:02
Find serial number on block, on C221 its on a flat spot by the oil filter base, it will start with C221-. I dont recall on BD220.
jeff
12-23-2003 15:07:09
 Re: Re: Re: Re: 303combine in reply to RPM, 12-23-2003 14:43:17
thanks i'll look ther tomorrow when it stops raining thanks. also i am parting out this combine if any one is interested
