wide front for H,, IH--or schwartz how to tell
pat,maplehillfrm
12-23-2003 21:55:54
hey guys I have a H that is in pieces, it has a wide front end on it, well unattached from her,, the tie rods appear to be to the back of the tractor if I remember right,, how can I tell if this is original or an aftermarket is there and easy way to do this,, I really havent checked it too much but did not see any markings,, thanks in advance, All this questions about WFE got me thinking, pat
Zak
12-24-2003 14:17:17
 Re: wide front for H,, IH--or schwartz how to tell in reply to pat,maplehillfrm, 12-23-2003 21:55:54
I just added a WFE to my 300. In addition to having the tie rods behind the axle, you may see 'SCHWARTZ' cast into the top of the uhhh arm thingies that the tie rods bolt to. I forget what they're called but I saw a name cast there on mine! Zak
Jim J
12-24-2003 08:03:46
On the factory IH wide front the center pivot is made of cast iron. All of the after market fronts that I know of the center pivot is made out pieces of flat iron welded together.
42FarmallH
12-24-2003 02:49:39
If the tie rods are behind the axle it is either later style IH, Schwartz, Speeco, or I think there was another aftermarket wide front. Here is a picture of a Schwartz heavy duty on my H:
third party image
Dave in CT
12-24-2003 09:25:37
 Re: Re: wide front for H,, IH--or schwartz how to in reply to 42FarmallH, 12-24-2003 02:49:39
What company/model parts and setup are you using to add power steering to your H? I'm thinking of doing exactly what you're in the process of doing - power steering with HD Schwartz wide front end.
Thanks,
Dave
42FarmallH
12-24-2003 11:03:19
 Re: Re: Re: wide front for H,, IH--or schwartz how in reply to Dave in CT, 12-24-2003 09:25:37
I'm using a Char-Lynn torque motor, hydraulic flow divider from Northern Tool & Equipment, machine shop is going to make the spacer needed to mount the torque motor (available from steelwheelranch). Hoses from local implement dealer or Runnings, whichever place I end up.
See my website>Link
Sorry>Link I don't have more up, just what I have done so far. No time or $$ lately to finish the project!
riverbend
12-24-2003 05:01:09
Did you add power sterring to that ?
42FarmallH
12-24-2003 08:25:07
 Re: Re: Re: wide front for H,, IH--or schwartz how in reply to riverbend, 12-24-2003 05:01:09
Not yet, but I have most of the parts rounded up to do it. Just need to find the time and additional $$ for hoses, etc.
