ChadS
12-24-2003 19:00:14
Re: carburator adjustment in reply to terry, 12-24-2003 15:17:42
Carb adjustments are kinda easy and kinda difficult, First,, start by adjusting the idle adjustment,, Warm up the engine, and idle it down as low as it will go, adjust the idle adjustment until the smoothest operation is achieved. should not lope of smoke at an idle. then,, open the throttle to the wide open position,, start by turning the load adjustment about 1.5 turns off the seat,, and then back it out until it will smoke,, then turn the adjustment screw in until it smooths out. and no smoke,, idle the engine back down and quickly open it back up,, should operate smoothly,, the float could be still not right,, could be overflowing the fuel bowl and coming out the metering stem,, make sure that the bowl bolts are tight, a vaccum leak could happen around the venturi, and will draw fuel up past the gasket and into the venturi, Hope this helps,, ChadS
