oil dipstick for H Farmall
Dean Mn
12-24-2003 17:39:01
I purchased an H Farmall with the engine froze as my first project. After a week of having oil sit in the cylinders with weight on the crank, I have now pulled off the head. All the pistons weem to be low in the cylinders so apparently I must have a broken crankshaft or connecting rods etc. The thing that surprises me is that I cannot find the oil dipstick alongside the motor anywhere, apparently it was an early model and not made with one. Your thoughts?
old
12-24-2003 20:11:34
 Re: oil dipstick for H Farmall in reply to Dean Mn, 12-24-2003 17:39:01
Hes cooorect on some of that I've seen them with dip sticks and with the other set up have you tried putting turpintine in the cylinders it works well to brake them free if you need an engine let me know I have and industeral H engine forsale
Will Sick
12-24-2003 17:54:17
The H has two petcocks on the oil pan to check the oil.They did not have a dipstick. As far as thge position of the pistons when two are clear up two will be clear down. If you stop in between that all four will be half way down.
Dean Myran
12-25-2003 06:34:28
 Re: Re: oil dipstick for H Farmall in reply to Will Sick, 12-24-2003 17:54:17
Thanks for the info!
