560 D, anyone know why
Marc
12-25-2003 06:33:37
Have a 560 Diesel, work's great in all gear's, but, won't go into 5th. Is that a big fix? Other wise run's and work's great.
hagan
12-25-2003 09:34:47
 Re: 560 D, anyone know why in reply to Marc, 12-25-2003 06:33:37
Hey make sure the tractor is in neutral with the brake set and then take the 3 bolts out that hold the shifter in place and take a long screwdriver or punch (be careful do not drop). Carefully take and shove the very left hand shifter slide on the top of the transmission foreward. Then get on tractor and see if it will move. If it will your shifter end is needing built up. I had to do this to mine and it was quite easy and 5th was the one hard to get into gear. GOOD LUCK & MERRY CHRISTMAS
Brian in MO
12-25-2003 08:05:05
Marc, I would be willing to bet the teeth on 5th gear is rounded off. If that is the case you would have to split the tractor and replace the gear. It is a pretty big job but worth doing. Brian
greasy John
12-25-2003 08:30:47
 Re: Re: 560 D, anyone know why in reply to Brian in MO, 12-25-2003 08:05:05
Brian it may be just a shift fork problem also. Does the shift lever go into the 5th position?
Does it grind at all if you try to shift it to 5th with the clutch partially in?? Dont know abt the 560 but on my 350 you can remove the cover where the belt pulley should mount and look at the 4th-5th gear sliders. John
greasy John
12-25-2003 08:30:16
