350IH was running and just quit
Donald l Anthon
12-25-2003 16:59:28
I was running my 350 utility today and it just stopped running. theres gas to the carb and 12 volts to the coil but not much of any spark Any ideas? Don
Donald L. Anthony
12-29-2003 08:04:27
 Re: 350IH was running and just quit in reply to Donald l Anthony, 12-25-2003 16:59:28
Thanks for the help out there, it turned out to be the points. Don
Muleskinnerbob
12-26-2003 20:55:30
If you cant find what is wrong by checking all the thing's in the one's before mine. Send me a email and I will give you a call if you send me your ph.# Most likely a loose wire or short some where.
dELBERT
12-26-2003 06:20:41
Bet my left hind leg it,s the points not opening or need replaced.
Jimmy King
12-25-2003 21:43:14
I had a 544 once that would do that and about the third time I found the problem one of the little wires on the coil apeared to be tight but it wasn't and it would break conection.
Greasy John
12-25-2003 20:22:10
Don ,my bet for weak spark is condenser!! Let us know?? John
twopop
12-25-2003 20:16:33
if you havent checked the points,do that FIRST.the rub block may have worn to the point that they wont open.KISS keep it simple !!!!!
Hugh MacKay
12-25-2003 20:10:18
Donald: I tend to agree with Dick on this one, either distributor cap or terminals on it.
Foz
12-25-2003 19:26:17
Walk inta the house, grab a cool one,kick back and worry bout it tommorrow ;)
Dick Davis
12-25-2003 18:02:36
Loose wire to plug or coil or cap. Broken, dirty, corroded rotor cap or rotor. Bad coil (rather unlikely) I'd check for wire loose or corroded. My nickel, Dick Davis - Merry Christmas
ChadS
12-25-2003 17:59:34
Check the plugs,, they may be bad,, the rotor button may be shorted,, the coil may have burned up,, Ignition switch may have went south,, just start by a process of elimination,, start with coil,, then the points, then the rotor, then the cap, the wires and the plugs may recheck the switch too,, got to be one of those things,, Hope this helps,, ChadS
