400 sediment bulb
hal
12-25-2003 17:29:23
does anyone know the proper way to clean the brass fuel filter that is in the sediment bulb? this one has two stud with real small thumb nuts and about 250 paper thin brass plates. are you to take this thing apart and clean each plate or is there an easier way? also does it go above the gasket for the bulb or does it set in the bottom of the bulb? how tight are the nuts supposed to be? all the farmalls that I have been around did not have a setup like this, they had the flat screen in the top of the sediment bulb above the gasket. how common are these and what is the special purpose for them?
Chuck's Repair
12-26-2003 10:38:39
 Re: 400 sediment bulb in reply to hal, 12-25-2003 17:29:23
I wouldn't take it apart unless you have a lot of time on your hands and want to.I haven't seen many of those filters.Just soak it in carbuerator cleaner and blow it out with compressed air.I think it would set in the groove in the sediment bowl just like the screen does.
