Whats this for?
Shaggy
12-25-2003 20:55:21
What I have is a pressure plate and a clutch that look like they are for a A,B or C. The clutch disk fit great but the pressure plate seems to have shorter fingers because the throw out bearing won't disengage it all the way. Here are the part numbers. Disk (4 button ceramic)384384R91 the cover is 384383R91 these are the number on the original IH box. Thanks Shaggy
sammy the RED
12-26-2003 10:53:05
 Re: Whats this for? in reply to Shaggy , 12-25-2003 20:55:21
They are for a 404 and 2404.
Shaggy
12-26-2003 22:16:30
 Re: Re: Whats this for? in reply to sammy the RED, 12-26-2003 10:53:05
The disks fit perfect in the Aor B flywheel and on the driveshaft and the pressure plate fit's and looks just like the one s for A-B BUT you can not adjust the throw out bearing enough to disengage the clutch. Do they make a thicker bearing?
Randy in NE
12-26-2003 04:12:31
These part numbers do not match up with either the Atwood or Rockford clutches for a C. These part numbers are in the range of 351xxxR1. Might be for an H or M.
