Extra bolt on alternator
Clete
12-26-2003 10:46:47
Got an alternator for the 12 volt conversion. Going by Bob M's diagram. There seems to be an extra screw connector,maybe a gound? There is the connector to batt and the 2 pigtails plus this other screw.What is is for and what do I need to do with it?
Bob M
12-26-2003 12:14:52
 Re: Extra bolt on alternator in reply to Clete, 12-26-2003 10:46:47
Clete - it's probably a terminal for an auxiliary ground connection. However if it's insulated from the end bell it may be a tach connection. If your alternator charges with the terminal disconnected (it should...) I'd just leave it as is.
Clete
12-26-2003 12:19:11
 Re: Re: Extra bolt on alternator in reply to Bob M, 12-26-2003 12:14:52
Bob...was hoping you would answer. Ikind of thought it was a ground or something, there is no insulation. Thanks for the quick response.
